AQWA user_force error
    • 富 佳
      Hi, i met a problem when i used aqwa user_force through python. The program stopped after about 30 steps, and show ANALYSIS ERROR USER_FORCE DLL ERROR NUMBER 1179901292. I simulated the two-bodies floating structure. Expected a answer.
      And i also want to know how to use use_force in Workbench.
    • Mike Pettit
      Are you able to share your Python script here?
      For running a Python user-defined force function through Workbench, you should turn on the time domain Analysis Settings option 'Connect to Server for External "user_force" Calculation', and use the option 'External Operation before Solving' to launch the Python server.
      Mike
    • 富 佳
      Thank you for much,I have solved my problem of python script.
      I also want to know  the detail of 'External Operation before Solving' for using in Workbench. Hope your response.
    • Mike Pettit
      Hello, I'm glad you got it resolved.
      The 'External Operation before Solving' option allows you to either:
      • Run a command, as if you were entering it in the Windows Command Prompt; or
      • Run a Python script, where the script can be defined directly in the Aqwa Workbench editor, or you can load a script from disk.
      Both of these operations are performed after the Aqwa input file has been generated, but before the solver is executed.
      I hope this helps!
      Mike
      • Lijie Yuan
        Hi,I’m currently experiencing the same problem. My question is :In the workbench interface, is it still necessary to follow the instructions in the manual, running the .py file first to establish the connection when running a Python user-defined force function ?
        By the way, what is the meaning of USER_FORCE DLL ERROR NUMBER 1?
        Thank you very much
        • Mike Pettit
          I've just posted an answer to this under your separate thread: /forum/forums/topic/aqwa-user-force/#post-356339
          Cheers, Mike
    • Lijie Yuan
      Is it possible for us to communicate via email to discuss issues in this regard?
      Yljgoodmail@163.com
      • Mike Pettit
        As an Ansys employee I'm not allowed to correspond outside of this forum, but maybe OP can help you out.
        Mike
Viewing 4 reply threads
  • The topic ‘AQWA user_force error’ is closed to new replies.
