May 10, 2019 at 5:11 am
ARCHANA26
Subscriberhello every one,
I am facing difficulty in plotting graph between y0.5 v/s X (spread rate/stream wise development of half with) for plane turbulent wall jet .
I have attached couture of velocity for my domain. please suggest how can i proceed for the solution is there any way to do in fluent or CFD post or I have to write UDF for this.Â
May 13, 2019 at 11:15 am
Forum ModeratorNot sure what you mean, but if you're trying to plot position of a region of speed if you create an isosurface of (for example velocity = 3m/s) you can plot the x & y position of that line. In 3d you'd get a surface to need to be a little more careful, in 2d it's easier.Â
I would check the mesh resolution as the contour looks a little odd at the larger x values.Â
- The topic ‘how to plot graph for stream wise development of half width for turbulent wall jet’ is closed to new replies.
3597
1283
1117
1068
983
