February 13, 2024 at 3:40 pm
Mohammad.Ali Ghiafi
SubscriberHi folks!
I try to transient thermal analysis in Piston which it has cyclic BCs. apply in 0.144 sec (in 180 step). I need to find after 3500 cycle (about 504 sec) what is final temperature in Piston.
As i know in this solution after every cycle i should put result temperature as Initial temperature for next cycle (as below schematic)
February 13, 2024 at 3:54 pm
Mohammad.Ali Ghiafi
SubscriberBut if i want to solve this solution i need to make 3500 “Transiant Thermal” in schematic. for shortcut i wrote a script code:
But when I run this script i recive an error :
System.InvalidOperationException: Connecting components Solution 2 and Setup 1 will introduce cyclic dependency
let me know how i can solve with scripting ?
- The topic ‘How to import transient thermal result as initial temperature in Ansys mechanica’ is closed to new replies.
Ansys Innovation Space
- APDL, memory, solid
- Meaning of the error
1415
1272
1119
1015
