May 2, 2019 at 7:30 pm
May 2, 2019 at 7:44 pm
peteroznewman
SubscriberIn Mechanical, click on Static Structural, then click on the Command Object button to insert a Command Object. In the text window that appears in the main window, type the following text:
ERESX, NO
That will change what the solver does normally, which is to take the stress calculated at the interior Gauss points and extrapolate it out to the nodes. It will instead just copy the stress from the Gauss points to the nodes.
Here is a Discussion on that point.
May 2, 2019 at 8:04 pm
May 2, 2019 at 8:25 pm
Sam Fares
SubscriberI noticed the Maximum principle stress goes above yield stress, but Equivalent stress remains below the yield. Why ?
May 2, 2019 at 9:11 pm
peteroznewman
SubscriberThe Equivalent Stress in the element is compared with Yield Strength to decide whether plasticity is occurring.
Equivalent Stress is the proper stress to use for ductile materials.
Maximum Principal stress uses different equations to combine the stress components and comes up with a different result.
You can look up the equations in a Solid Mechanics textbook.
In a Uniaxial Tensile Test, there is only one stress component Sxx and in that case, the Equivalent Stress and the Maximum Principal stress equations give the same answer, which is Sxx.
May 2, 2019 at 9:17 pm
Sam Fares
SubscriberThank you so much Peter!!
- The topic ‘NonLinear, Elastic Plastic Material’ is closed to new replies.
5884
1306
