Floating Point Exception Ansys Fluent
    • Ashraf El Naggar
      I am working on Battery Pack Thermal Analysis for an Electric Vehicle. Whenever I get to the point of pressing "Run Calculation", the solver displays 1 iteration only then displays some info and "Floating Point Exception". Here are the messages displayed in the console:
      iter energy uds-0 uds-1 time/iter
      1 1.6096e-07 7.8111e-07 7.7842e-07 0:00:40 10
      Stabilizing temperature to enhance linear solver robustness.
      Stabilizing temperature using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: temperature Stabilizing uds-0 to enhance linear solver robustness.
      Stabilizing uds-0 using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: uds-0 Stabilizing uds-1 to enhance linear solver robustness.
      Stabilizing uds-1 using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: uds-1
      Error at host: floating point exception
      ===============Message from the Cortex Process================================
      Compute processes interrupted. Processing can be resumed.
      Error at Node 3: floating point exception
      Error at Node 2: floating point exception
      Error at Node 5: floating point exception
      Error at Node 4: floating point exception
      Error at Node 1: floating point exception
      Error at Node 0: floating point exception
      Error: floating point exception
      Error Object: #f
      I am new to Ansys Fluent, so I will be glad if anyone helps me throughout this problem. Thanks in advance!
    • Nilay Pedram
      Please check/verify the solver settings, boundary conditions applied to your problem and make sure they are set correctly.
      Thanks!
      • Ashraf El Naggar
        Thanks for your response, I will mention what I’ve done until I got this error. If you have any feedback that can guide me throuout the analysis please provide me with it.
        1- I defined conditions for air flow inside the enclosure and obtained the velocity profile as shown below without any problem.
        2- I enabled energy equation, MSMD battery model, and turned the time into transient.
        3- I defined required parameters and printed the number of series cells, which appeared to be 15 as it should be.
        4- I defined the required materials and assigned them to suitable cells, tabs, busbars.
        5- I initialized the model and pressed run calculations.
        6- Floating point exception error.
    • Ashraf El Naggar
  • The topic ‘Floating Point Exception Ansys Fluent’ is closed to new replies.
