Ansys Learning Forum Forums Discuss Simulation General Mechanical Dimension dependend on position in pattern Reply To: Dimension dependend on position in pattern
ErKo
Hi
You need one section for each beam – it is possible to automate the section creation and section assignment (to line body) via mechanical scripting.
It needs a script InternalObject which is not great - still see below on how to create a rectangular/square cross section inside Mech. using Scripting:
model = ExtAPI.DataModel.Project.Model
crosssection_group=model.InternalObject.AddCrossSectionGroup()
cross_sec=ExtAPI.DataModel.GetObjectsByType(DataModelObjectCategory.CrossSections)[0].AddRectangularCrossSection()
You can take the above and add  square sections and assign them as needed.
All the best
Erik
