Dimension dependend on position in pattern
    • Jan Stüber
      Hi Guys,
      for a better understanding of my problem a short example: I want to place  50 square beams in a linear pattern. The first beam has dimensions of 50 mm x 50 mm. For each beam following, the dimensions are reduced by 1mm, so beam two has dimensions of 49x49, beam 3 48x48, beam 4 47x47 and so on.
      I could generate one sketch for each beam, but is there a less exhausting way? Or do I need to duplicate the first sketch, and then change only the dimensions needed? For now iam working in DesignModeler
      Best regards
      Jan
    • ErKo
      Hi
      You need one section for each beam – it is possible to automate the section creation and section assignment (to line body) via mechanical scripting.
      It needs a script InternalObject which is not great - still see below on how to create a rectangular/square cross section inside Mech. using Scripting:
      model = ExtAPI.DataModel.Project.Model
      crosssection_group=model.InternalObject.AddCrossSectionGroup()
      cross_sec=ExtAPI.DataModel.GetObjectsByType(DataModelObjectCategory.CrossSections)[0].AddRectangularCrossSection()
      You can take the above and add  square sections and assign them as needed.
      All the best
      Erik
  • The topic ‘Dimension dependend on position in pattern’ is closed to new replies.
