Ansys Learning Forum Forums Discuss Simulation Preprocessing Is it possible to change the gravity value in static structural analysis? Reply To: Is it possible to change the gravity value in static structural analysis?
20me013.jelson
Hey peteroznewman, thanks for the input. I did try that method then compared the results with standard earth gravity, but there was no much difference between Martian gravity and earth gravity. The difference was just (+ or -)0.001. And I even tried without having any sort of gravity input, still the results were the same as before.
Thanks in Advance.
