April 27, 2019 at 2:09 am
xgteml
SubscriberHello,
How would one go about finding the needed values for the Yield Strength and Tangent Modulus within the bilinear isotropic hardening to properly simulate the plastic deformation of aluminum alloy?
Thank you!
April 27, 2019 at 3:01 am
April 27, 2019 at 3:12 am
April 27, 2019 at 10:46 am
peteroznewman
Subscriber Yes, Yield Strength in the Bilinear Isotropic Hardening material model is just the yield strength of the material.
April 27, 2019 at 5:10 pm
April 27, 2019 at 6:36 pm
xgteml
SubscriberAre they along all three axis?
April 28, 2019 at 2:21 am
peteroznewman
SubscriberThe three lines are Minimum, Average and Maximum values of Stress. You can turn off the Minimum and Average if you only want to see the Maximum on the Tabular data window.
April 28, 2019 at 2:24 am
xgteml
SubscriberThank you very much.
November 4, 2019 at 4:03 am
yashpalsingh7693
SubscriberHello sir,
How would any one finding the needed values for the Yield Strength and Tangent Modulus within the bi-linear isotropic hardening to properly simulate the plastic deformation of Niti alloy (Nitinol)?
Thank you
July 25, 2021 at 9:54 pm
Jemuli2021
Subscriber.Hello,
I wanted to use the multilinear isotropic hardening of aluminum 1000 series . I could not get the data of plastic stress and strain(experimental data) . Can any one help me with the data?
September 30, 2021 at 7:12 pm
- The topic ‘Bilinear Isotropic Hardening Values’ is closed to new replies.
6635
1312
