Ansys Learning Forum Forums Discuss Simulation General Mechanical Using Pythion Command Objects in ANSYS Rigid Dynamics Reply To: Using Pythion Command Objects in ANSYS Rigid Dynamics
Erik Kostson
Hi
THE act script commands should be the same or at least similar as any other simulation system (say static).
You should be able to record also and see what that is:
https://www.padtinc.com/2023/08/08/crash-course-ansys-mechanical-scripting/
All the best
Erik
