February 8, 2024 at 3:45 am
Omar Zaki
SubscriberI am trying to start Fluent Meshing. Processor is AMD Ryzen Threadripper PRO 7995WX.
I get the following error:
Welcome to ANSYS Fluent 2023 R2
Copyright 1987-2023 ANSYS, Inc. All Rights Reserved.
Unauthorized use, distribution or duplication is prohibited.
This product is subject to U.S. laws governing export and re-export.
For full Legal Notice, see documentation.
Build Time: Aug 18 2023 08:31:10 EDT Build Id: 10213
Connected License Server List: ######
This is an academic version of ANSYS FLUENT. Usage of this product
license is limited to the terms and conditions specified in your ANSYS
license form, additional terms section.
Host spawning Node 0 on machine "OmarZaki" (win64).
[mpiexec@OmarZaki] wmain (mpiexec.c:2165): assert (pg->intel.exitcodes != NULL) failed
[mpiexec@OmarZaki] HYD_sock_write (..\windows\src\hydra_sock.c:387): write error (errno = 34)
What would be the issue?
February 9, 2024 at 1:17 pm
MangeshANSYS
Ansys EmployeeHello,Â
Can you please try running using openmpi by selecting openmpi when starting from fluent launcher OR adding the line below to your fluent launch command ?Â
-mpi=openmpi -
February 9, 2024 at 2:36 pm
Omar Zaki
SubscriberÂ
Thanks Mangesh for replying. I tried many things including installing Intel MPI and Microsoft MPI and tried both without any success. I also tried the mpiexec test line
c:\Program Files\ANSYS Inc\v232\ansys\bin\winx64>ANSYS232.exe -np 2 -mpitest
but it gave me the same error again:
I also tried with Admin Privileges, but also without success. Additionally, I tried both Intel MPI and Microsoft MPI, both failed to launch.
The only case Fluent launched when I start with one process, since MPI is not needed.
I downgraded to Ansys 2023 R1, and it is working flawlessly now. I think it is a bug with Ansys 2023 R2. I wonder if there is a platform to report bugs like this.
February 9, 2024 at 3:09 pm
MangeshANSYS
Ansys Employeeplease try
-mpi=intel2018
It simply could be an issue with combination of your system and newer version of MPI -
February 10, 2024 at 5:39 am
Omar Zaki
SubscriberStill the same error with -mpi=intel2018
Any other ideas?
February 12, 2024 at 4:17 pm
MangeshANSYS
Ansys Employeewmain (mpiexec.c:2165): assert (pg->intel.exitcodes != NULL) failed
if you are installing MPI services please cache your credentials- See this 3rd party link for similar errorÂ
https://community.intel.com/t5/Intel-HPC-Toolkit/Intel-MPI-2019-3-can-t-work/m-p/1143101 - How is Fluent being launched ? Please try using a directory with write permissions. Use a start in directory without spaces, something like
C:\temp\fluent_test - In your command line for ansys232, I noticed that you are starting in the Program files directory. Similarly can you try launching from a folder with write permissions ? also try addingÂ
-smp
to your command for launching Ansys Mechanical - are you trying to run on only opne machine or more than one machines ? if more than one then also check firewalls and access to shared drives
hope this helps
February 12, 2024 at 11:13 pm
Omar Zaki
Subscriber1. See this 3rd party link for similar errorÂ
https://community.intel.com/t5/Intel-HPC-Toolkit/Intel-MPI-2019-3-can-t-work/m-p/1143101Tried the solutions offered on the topic, with no success. I am pretty sure it is an Ansys problem not an MPI problem
2. How is Fluent being launched ? Please try using a directory with write permissions. Use a start in directory without spaces, something like
C:\temp\fluent_testTried this, no success. Same Error
3. In your command line for ansys232, I noticed that you are starting in the Program files directory. Similarly can you try launching from a folder with write permissions ? also try addingÂ
-smp to your command for launching Ansys MechanicalI am trying to launch Fluent not Ansys Mechanical.
4. are you trying to run on only opne machine or more than one machines ? if more than one then also check firewalls and access to shared drives
It is only 1 machine, and I checked the firewall restrictions. There is nothing to be done about it.
Additionally, I tried copying the MPI files from 2023 R1 to the newer versions, without success. I also tried the most recent version 2024 R1, which gave me the same error.
I am not sure what should be done next. How can I contact customer service about this? (I have a university academic research license)?
February 13, 2024 at 1:49 pm
MangeshANSYS
Please reach out to your Ansys Sales Account Manager and reference this thread and my name.
thank you
May 17, 2024 at 5:20 pm
MangeshANSYS
Ansys EmployeeHere is what worked for Omar
"C:\Program Files\ANSYS Inc\v241\fluent\ntbin\win64\fluent.exe" 3d -r24.1.0 -mpi=intel2018 -peth -t6
- The topic ‘Fluent crash on starting’ is closed to new replies.
- affinity not set
4167
1487
1363
1194
