February 3, 2024 at 4:32 am
SAlissa2
SubscriberHello I am having issues on a transient structural analysis. I'm simulating an object that is supposed to drop on to a flat plate and bounce back up. However when I set it up in workbench it phases through the plate. I set up all my connections accordingly and I am not sure what is causing it to phase through the plate. If someone can please assist with this that would be much appreciated.
February 6, 2024 at 2:14 pm
Akshay Maniyar
Ansys EmployeeHi Shady,
Can you share the analysis settings image that you are using? Maybe the timestep used is not small enough to capture the contact properly. Try reducing the timestep and see if it helps.
Thanks,
Akshay Maniyar
- The topic ‘Object Phasing through Plate’ is closed to new replies.
