April 19, 2019 at 1:45 am
April 22, 2019 at 8:55 pm
peteroznewman
SubscriberHello Tony,
If you create a Workbench Project Archive .wbpz file, you can attach that using the Attach button that appears after you post your reply and I will take a look at your geometry.
April 25, 2019 at 6:44 pm
antonio.caiaia
SubscriberHi Peter,
Firstly thank you for the attention ,
Here you have the file, thank youÂ
April 25, 2019 at 9:14 pm
peteroznewman
SubscriberHi Tony,
You only have lines in SpaceClaim, you have to turn them into surfaces using the Pull tool. Try reviewing some of the SpaceClaim tutorials on this site.
Please reply with a sketch of the model you want to build.  Also which edges have what kind of thermal boundary condition.
April 25, 2019 at 9:42 pm
antonio.caiaia
SubscriberHi Peter,
That's the problem , I have only lines. In fact what I want is a surface (a rectangular) with 1metter as width and 2metters as height. Where is the tool pull?? are the boundary conditions entered in the SpaceClaim or in thee Ansys Mechanical while meshing ?? Because the problem I'm facing up now is the geometry that doesn't fit when I try to double click in the model . Thank youÂ
April 26, 2019 at 12:24 am
peteroznewman
Subscriber Hi Tony,
Here is a list of SpaceClaim tutorials.
/forum/forums/topic/spaceclaim-teaching-curriculum-materials/
Watch them to learn how to use the Pull tool to make a surface.
April 26, 2019 at 12:47 am
- The topic ‘Import a geometry from SpaceClaim two ANSYS Mechanical’ is closed to new replies.
5879
1306
