Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Calculation diverges when mesh is refined › Reply To: Calculation diverges when mesh is refined
The pressure outlet is at the top. Those protruded rectangular fins are the heated walls. The side walls are adiabatic. Â
As I said, the coarse mesh did work without error and got some results with visible boiling. Coarcer mesh also has jump in cell size and works good.
But, as soon as I replaced the mesh with finer one (2 times finer), the simulation diverges.Â
The mesh chek for coarse gives following output in Fluent:
The mesh check for finer mesh gives the following output in Fluent:
Minimum Orthogonal Quality = 1.00000e+00 cell 3908 on zone 23 (ID: 23410 on partition: 2) at location ( 3.87500e-03, 1.49462e-01)
The zoomed-out and zoomed-in snapshots of the coarse and fine meshes are attached here.Â
