January 31, 2024 at 8:14 pm
Carson Moseley
SubscriberI am attempting to export as a .dxf in HFSS, but regardless of how I go about it, I am only given graphics options (image formats only). The Help manual just says to use Modeler --> Export, but that clearly is not working in my case because it is being treated as a graphic when it is a 3D model. What settings do I need to change / adjust to remedy this?
February 1, 2024 at 12:30 pm
Jason Kalogeropoulos
Ansys EmployeeHello Carson,
The option of exporting to .dxf (and other formats, let’s say .gds .obj etc.) your 3D model,  should be available following the process you describe.
Let me ask a question; What version of HFSS do you currently use? Is it a student version?
Kindly,
Jason.-
February 1, 2024 at 5:58 pm
Carson Moseley
SubscriberHi Jason,
Thanks for your reply. I'm currently using the latest release of the student version. Is this a limit of the student version? I was having trouble finding documentation on the differences of versions so I couldn't confirm for myself.
February 5, 2024 at 9:04 am
Ansys EmployeeHi Carson,Â
Unfortunately, the option to export a model as .dxf file in the student version isn’t available. ÂKindly,
Jason.
- The topic ‘Issues exporting as .dxf in HFSS’ is closed to new replies.
- Link the Circuit to 3D Terminals
- Magnetic Dipole moment calculation
- Integration lines or U Axis Line for circular and rectangular ports
- Core Loss in ANSYS MAXWELL Eddy Current solution
- exporting and importing my Netlist for my external circuit
- Error of Metal Fraction in Icepak Classic.
- The unit of theta in Is*sin(2*pi*fre*Time+theta-2*pi/3)
- 2D transient simulation -torque issue
- Two way coupling for Maxwell and thermal problem
4607
1515
1386
1209
