Ansys Learning Forum Forums Discuss Simulation Electronics AnsysEDT SLURM tight IntelMPI integration issue Reply To: AnsysEDT SLURM tight IntelMPI integration issue
randyk
Please create folder:  $HOME/anstest
Then create file:  $HOME/anstest/job.sh   with the following contents(correct partition and installation path):
#!/bin/bash
#SBATCH -N 3
#SBATCH -n 12
#SBATCH -J AnsysEMTest     # sensible name for the job
#SBATCH -p default         # partition name
InstFolder=/opt/AnsysEM/v232/Linux64
JobFolder=$(pwd)
# SLURM setup
export ANSYSEM_GENERIC_MPI_WRAPPER=${InstFolder}/schedulers/scripts/utils/slurm_srun_wrapper.sh
export ANSYSEM_COMMON_PREFIX=${InstFolder}/common
srun_cmd="srun --overcommit --export=ALL  -n 1 -N 1 --cpu-bind=none --mem-per-cpu=0 --overlap "
export ANSYSEM_TASKS_PER_NODE="${SLURM_TASKS_PER_NODE}"
# Setup Batchoptions
echo "\$begin 'Config'" > ${JobFolder}/${JobName}.options
echo "'HFSS/RemoteSpawnCommand'='scheduler'" >> ${JobFolder}/${JobName}.options
echo "'HFSS 3D Layout Design/RemoteSpawnCommand'='scheduler'" >> ${JobFolder}/${JobName}.options
echo "'HFSS/MPIVersion'='2021'" >> ${JobFolder}/${JobName}.options
echo "'HFSS 3D Layout Design/MPIVersion'='2021'" >> ${JobFolder}/${JobName}.options
echo "'tempdirectory'='/tmp'" >> ${JobFolder}/${JobName}.options
echo "\$end 'Config'" >> ${JobFolder}/${JobName}.options
# skip OS/Dependency check
export ANS_IGNOREOS=1
export ANS_NODEPCHECK=1
# MPI timeout set to 30min default for cloud suggest lower to 120 or 240 seconds for onprem
export MPI_TIMEOUT_SECONDS=120
#copy test project
cp ${InstFolder}/schedulers/diagnostics/Projects/HFSS/OptimTee-DiscreteSweep.aedt ${JobFolder}/OptimTee-DiscreteSweep.aedt
# Submit AEDT Job (SLURM requires 'srun' and tight integration change to the slurm_srun_wrapper.sh
${srun_cmd} ${InstFolder}/ansysedt -ng -monitor -waitforlicense -useelectronicsppe=1 -distributed -machinelist numcores=12 -auto -batchoptions ${JobFolder}/${JobName}.options -batchsolve TeeModel:Nominal:Setup1 ${JobFolder}/OptimTee-DiscreteSweep.aedt
$ cd $HOME/anstest/
$ dos2unix $HOME/anstest/job.sh
$ chmod +x $HOME/anstest/job.sh
$ sbatch $HOME/anstest/job.sh
Does this solve successfully, does it distribute across the three machines?
thanks
Randy
