April 15, 2019 at 2:16 pm
terwilliger12
SubscriberHello,
One of the researchers in an area I support recently had ANSYS ICEM CFD 19.1 installed and he noticed when trying to import a geometry via File >> Import Geometry >> Legacy that "STEP/IGES" is no longer available like it was in the old version he was using (he thinks it was version 13 or 14). Is it possible to import STEP/IGES files in ICEM CFD 19.1? If so, what is the process?
Thanks,
Ron
April 16, 2019 at 4:03 pm
pjstopfo
Ansys EmployeeHi Ron,
ICEMÂ 19.1 uses a different set of CAD readers from earlier versions, called the 'Workbench Readers'. These are accessed through File > Import Model. This is why the old readers in File > Import Geometry are labelled as 'Legacy'. You should be able to import STEP, IGES and several other formats using the 'Import Model' option.
Phil
April 22, 2019 at 9:37 pm
terwilliger12
SubscriberThanks pjstopfo, that was the information the researcher needed, much appreciated!
February 28, 2020 at 4:09 pm
Sai Guruprasad Jakkala
SubscriberI receive the following error when I try to import the model in STL and IGS format.
ERROR:
 pIPartMgr->AttachAssembly() failed!
It also appears when I import the original Solidworks part file.
Any reason for this error. I tried STP format also.
- The topic ‘ICEM CFD 19.1 – Unable to import STEP/IGES geometries’ is closed to new replies.
5834
1305
