Ansys Learning Forum Forums Discuss Simulation Fluids Flow Through an Object Inside Enclosure – ANSYS Fluent Reply To: Flow Through an Object Inside Enclosure – ANSYS Fluent
Mohamed Salman Mohamed Haniff
Hi Rob,
Thank you for your reply. May I know how to share the topology between the two bodies in the design modeler?
I tried as shown below, but I got the same results with flow going past the pipe.
