Ansys Learning Forum Forums Discuss Simulation Fluids How to vary specific heat with spatial co-ordinates not with Temperature Reply To: How to vary specific heat with spatial co-ordinates not with Temperature
Yes, which I'm trying to understand. If you set the property with position aren't you assuming a result of the combustion process rather than modelling it?Â
