Ansys Learning Forum Forums Discuss Simulation Fluids Variable density for solid object Reply To: Variable density for solid object
If you're setting a material property why do you need to also set that property to 1.225 kg/m3? I can understand some compression effect on a wall, so 40 or 430, but not the reason for the second IF.
