Ansys Learning Forum Forums Discuss Simulation Photonics Parameter sweep error [Nanopost] Reply To: Parameter sweep error [Nanopost]
Niki Papachristou
Hi Xie,
Thank you for reaching out to us! This means that you dont have data on your results. In your case, I would do a first simple run on my model and check that it collects the data that I am directing on the results window in the Edit Parameter Sweep.
Kind Regards,
Niki
