Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › User defined support condition › Reply To: User defined support condition
January 26, 2024 at 7:10 am
Thank you for the reply.
what do you mean by small motions and large motion?
I had model a solid body below the shell. The body is fixed and the contact between the body and shell is frictional.
Does this frictional contact resisit the motion in Y-direction?
I also have a zero displacement support at bottom along Z-dierction.
Is that correct?
