Ansys Learning Forum Forums Discuss Simulation General Mechanical Squeezing two rubbers and water Reply To: Squeezing two rubbers and water
dlooman
I don't see a way to model the water for a couple reasons.  First, water isn't a structural material and doesn't have any shear stiffness.  Second, it appears you need to specify its geometry in the deformed cavity created by the rubber bodies.  There's no way to do that.
