Ansys Learning Forum › Forums › Discuss Simulation › Photonics › Run FDTD optimization on cluster without opening the CAD › Reply To: Run FDTD optimization on cluster without opening the CAD
@xh19363,Â
Just to add, API/script (lumapi, lumopt) is part of our CAD/GUI environment and will require a GUI connection and a GUI license to run.Â
>Lumerical product components and licensing overview – Ansys OpticsÂ
>Python API overview – Ansys OpticsÂ
If you want to run the scripts without a GUI/Desktop connection, we have the KB below as a workaround. With newer versions of Lumerical you can use the "QT_QPA_PLATFORM" variable together with (hide=True) option. For the older versions you can use virtual display (Xvfb). Note that running the script (.py or .lsf) even with the CAD/GUI 'hidden' will always checkout a GUI license.Â
>Running CAD jobs on headless Linux systems – Ansys Optics
