Ansys Learning Forum Forums Discuss Simulation Fluids Volume fraction problem in fluent Reply To: Volume fraction problem in fluent
javat33489
The methane phase not only accumulates, it does not reach the outlet. On the output graph I see 0 kg/s.
I also tried adding surface tension to this mixture and setting the methane phase to the particles, but that didn't help.
I also tried to model flow velocity instead of flow rate, but then my continuity increases and the calculation also fails with an error.
