Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › PSD Response – Which stress value is to be taken to compare the yield strength › Reply To: PSD Response – Which stress value is to be taken to compare the yield strength
January 24, 2024 at 2:01 pm
Yes, if the design doesnot allow the stress to exceed yield then you can consider it failed. But, one should look for the spread of the stress - is the spread local or say through section yielding.
Ashish Khemka
