Ansys Learning Forum Forums Discuss Simulation Fluids AQWA LINE: wrong angle of the principle axes of the cut water plane area Reply To: AQWA LINE: wrong angle of the principle axes of the cut water plane area
K. H.
Hi, thank you for your answer. How did you calculate the GMx and GMy without the use of the principal second moments of area of the water plane?Â
