Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Error when setting up current sources › Reply To: Error when setting up current sources
Hi Shravan,
Thank you for reaching out to the Ansys learning forum, your patience is much appreciated.
Please let us know the reason for using Ansys Maxwell for the coplanar waveguide simulation. I assume the signal frequency would be in the GHz range for your simulation. These microwave structures are generally analyzed using Ansys HFSS. Kindly check if you are using the correct Ansys tool as per your requirements.
If you are new to simulation, then please go through the "Coplanar Waveguide" model provided in "Open Examples>HFSS>Trasnmission Lines" on the ribbon area of the Desktop tab.
Best regards,
Praneeth.
