April 11, 2019 at 8:16 am
Max4
SubscriberHello,
I have a question about the UDF for the specific heat in FLUENT.
The unit of the Temperature is Kelvin?
Moreover the value of Tref should be set in the Materials Panel?
I wrote this UDF for calculating the specific heat ( in J/kg.K):
#include "udf.h"
DEFINE_SPECIFIC_HEAT(my_user_cp, T, Tref, h, yi)
   real cp;
   cp = 5.661*T + 551,21;
   *h = cp*(T-Tref);
   return cp;
Maxime
April 11, 2019 at 8:51 am
Amine Ben Hadj Ali
Ansys EmployeeYes it is in Kelvin. Yes Tref is set in the material panel.
For a simple formulation that you have it is enough to use polynomial function.
April 11, 2019 at 9:00 am
Max4
SubscriberThank you for your answer.
Maxime
- The topic ‘Specific Heat Capacity – UDF’ is closed to new replies.
1676
1387
1248
