Ansys Learning Forum Forums Discuss Simulation Fluids Particles didn’t show up when using the DPM volume injection Reply To: Particles didn’t show up when using the DPM volume injection
If you open the Particle Track panel, then change the size/display option can you see them? At 2.5microns the particles will follow the flow, and are also very small so may not be easily seen.
