Lift distribution across wing
    • acgerrard
      Hi all,
      I was wondering if there is a way to generate the lift distribution on a 3D wing in Fluent? I have attempted to get the pressure coefficient along the wing by using a plane and across the component itself. Is there a way that doesn't involve untangling all the points from the cp graph?
      Thanks,
      Alasdair
    • Keyur Kanade
    • acgerrard
      Great, thank you!
    • Karthik Remella
      Administrator
      These Cornell courses are now a part of Ansys Innovation Courses (AICs). Please take a look at this link here.nnPlease also take a look at our other Fluids courses.nThank you.n
      The Cornell course is free, so register & watch the lectures. n
    • Karthik Remella
      Administrator
      Hello,nIf your question is how to access the Cornell tutorial for setting-up a 3D transonic flow over a wing, then this content in the link you are sharing has been moved to a new location. Here is the new location to this same Cornell content (same link that I already shared with you in my earlier post). You should be able to go through this tutorial and learn about how to model a 3D wing and generate the lift force distribution..nIf you have a specific question.please create a new post and we will be happy to help you with it.nThanks.nKarthikn
Viewing 5 reply threads
  • The topic ‘Lift distribution across wing’ is closed to new replies.
