April 9, 2019 at 12:37 pm
April 9, 2019 at 2:34 pm
DrAmine
Ansys EmployeeAre you reading a State file? Is it the same result file as two-weeks ago? Can you post the chart definition? Any other information is welcome here.
April 9, 2019 at 3:02 pm
April 9, 2019 at 3:24 pm
tubiy
SubscriberIt happens to me specifically for this simulation.
Another simulation is fine.
Two weeks ago it also worked for this simulation, and the only thing I did now was a calculation update.
April 9, 2019 at 3:27 pm
DrAmine
Ansys EmployeeCheck if you have valid transient data under time step selector. Launch Post outside of the WB for further debugging. -
April 9, 2019 at 3:57 pm
tubiy
Subscriber"Check if you have valid transient data under time step selector" - where?? I would be glad if you could elaborate more.
I can say I can create a contour for the last time steps.
Best regards,
Tubiy
April 9, 2019 at 4:45 pm
tubiy
SubscriberFurthermore, I returned the simulation to the time I took out the previous chart and it still gives me the same error.
April 9, 2019 at 6:20 pm
DrAmine
Ansys EmployeeTry access the time steps in the time step selector (if one with clock). You might even connect to a new Result component to start with clean state. -
April 9, 2019 at 6:29 pm
tubiy
SubscriberI can get results as the temperature contour at the recent time steps as I mentioned.
The problem is only in the chart no matter whether it is a surface or a point depending on the time, it simply shows an error.
Best regards,
Tubiy
April 9, 2019 at 6:35 pm
DrAmine
Ansys EmployeeCan you just use transient sequence for a variable at a point? -
April 9, 2019 at 7:04 pm
tubiy
SubscriberThat's really what I tried to check, and also a transient sequence at a point it gave me the same error.
Best regards,
Tubiy
April 10, 2019 at 4:00 am
DrAmine
Ansys EmployeeHave you tested with CFD Post outside the workbench. Here pay attention to what is printed in the command prompt of Post. -
April 10, 2019 at 7:53 am
April 10, 2019 at 1:01 pm
DrAmine
Ansys EmployeeIf you are at research institute please get in touch with ASC who can then try to highlight that for his local support. Without having access to the data it is hard to provide any further help here. As ANSYS Stuff I cannot exchange data on this open community. You might though upload your data perhaps some other community members help you further.
- The topic ‘error in CFX’ is closed to new replies.
5824
1305
