Ansys Products
Ansys Products
How to create composite layer using solid element ansys workbench?
    • Kavi Pradhap M
      Greetings of the Day!!
      I am able to create layered element for solid geometry using solid185 in ansys apdl using element option k3. How to do the same in ansys workbench without usin ansys acp.
      regards
      kavi
    • Onkar Patil
      Hi Kavi,
      Ansys Mechanical provides a convenient way to define simple layered sections for a surface body to simulate composite materials. This KM highlights several key points in defining layered sections and post-processing the results in Ansys Mechanical. Layered Sections in Ansys Mechanical.
      However for more advanced analysis of composites in complex geometries, please refer to Ansys Composite Prepost (ACP).
      Hope this helps.
      Regards
      Onkar
    • Govindan Nagappan
      The only options are using a command object with APDL commands or using ACP to build the solid composite
  • The topic ‘How to create composite layer using solid element ansys workbench?’ is closed to new replies.
