January 16, 2024 at 5:26 pm
141030
SubscriberI currently have a 2022 F1 car model and every repair and prepare task comes up with no errors or issues in the model. However, when the model is inputted into a watertight geometry workflow and tries to create a surface mesh, it comes up with errors and fails. Fluent says to check Diagnostics for any errors but as I stated above, none are appearing. What is going wrong with the model or should I convert it to a facet model before using fluent? Thanks!
.png)
January 18, 2024 at 6:03 pm
Luca B.
Forum ModeratorCan you also share fluent transcript file or the complete error message.
Thanks
Luca
January 22, 2024 at 12:39 am
141030
SubscriberHey, unfortunately I lost that file and error message but I remember it containing "can't close face" and "overlapping edge at bn 'x, y' coordinate"
January 24, 2024 at 11:59 am
Luca B.
Forum ModeratorIt is not simple to identify the issue. I can suggest you to check again geometry issue using repair tools. Is could be that some hard edges, overlapping surfaces or similar issue are still present and block mesh generation.
Luca
- The topic ‘Model Error-Free But Fails in Fluent’ is closed to new replies.
5694
1891
1419
1305
