January 13, 2024 at 6:09 am
Melvin C Joshy
SubscriberHi, I am a beginner. I am creating a microchannel with sinusoidal roughness. I have imported the coordinates file into design modeller and created the surface body for 2d analysis. I have meshed the geometry and provided the named selections. However it is not appearing in the fluent solver and I am not able to provide the BCs. The following is being displayed in BC.
January 15, 2024 at 11:57 am
Forum ModeratorIn Meshing check for Contact Regions. If the geometry is small the automatic checks can pick up false positives. Note, building models in microns (as a unit) can be problematic as the CAD kernels don't resolve at that scale. It's often better to build in mm or m scale using the micron value - so a 20micron channel isn't 20e-6m but is 20mm; then scale in Fluent.Â
- The topic ‘Named Selections not appearing in Fluent solver’ is closed to new replies.
- affinity not set
4067
1487
