Electronics
Electronics
The quality of some mesh elements is not acceptable for solution
    • Joe Hui
      I am trying to measure the self-inductance and mutual inductance between four coils using maxwell 3D with eddy current solution type. The coils are made with polygon helix, and have these specifications:
      Polygon segments = 8
      Polygon radius = 0.6mm
      Start Helix Radius = 155mm
      Radius change = 0
      Pitch = 1.40mm
      Turns = 11
      Segments per turn = 36
      Righthanded = 1
      Whenever I analyze this coil system, I will get this error: The quality of some mesh elements is not acceptable for solution. Please check the geometry for issues in the following location (in meters): X=-0.152844, Y=0.0243683, Z=0.00395514, which points to the geometry of the coil. However, no matter how I change the mesh settings, such as adjusting resolution, using dynamic surface resolution, and curvilinear meshing to all curved surfaces. It does not work. I even try adjusting the configuration above but remaining the same general shape; it does not fix this error.  Another method I tried is to add the environment variable skip mesh =1, but it doesn't seem to apply to the application. If you know how to fix it, please comment below.
    • GLUO
      Please go to design settings and check "skip mesh checks" under the validation tab.
      GL
  • The topic ‘The quality of some mesh elements is not acceptable for solution’ is closed to new replies.
