Ansys Learning Forum Forums Discuss Simulation Fluids CHT with MRF – solid cell zone sources not generating heat Reply To: CHT with MRF – solid cell zone sources not generating heat
SVV
Are you using conformal or non-conformal interface? Can you try with hex or poly mesh. It is also recommended to use a refined mesh.
