Ansys Learning Forum › Forums › Discuss Simulation › Fluids › CHT with MRF – solid cell zone sources not generating heat › Reply To: CHT with MRF – solid cell zone sources not generating heat
January 4, 2024 at 2:25 pm
Hi Nicholas,
Are you providing rotation to your solid cell zone as well. If you are facing issue with frame motion in solid zone, I would recommand using moving mesh/sliding mesh or else cell zones may become disconnected.
Note that a solid zone cannot move at a different speed than an adjacent solid zone; for such a situation, you must instead use Solid Motion.
If I got your question wrong, could you please share more details on how you are setting up the frame motion and source term in solid cell zone.
