Ansys Learning Forum Forums Discuss Simulation Fluids Calculating the Kv value of a valve Reply To: Calculating the Kv value of a valve
RG
I think you want to constraint your results i.e. dp=1 bar. I guess you have to increase pressure at inlet till you get dp =1. Remember here pressures are in bar. You have to take into pa while calculating Q and kv
