March 28, 2019 at 8:47 am
ikra
SubscriberHi all,Â
I am modeling a copper soil using ansys Maxwell. I want to apply a current in term of frequency to the pad and find the inductance, but I have this error "mfsolver fails. The most likely reason is that the system matrix is badly conditioned.. 1%".Â
Thank you for your help.Â
April 2, 2019 at 2:05 pm
Mark Solveson
Ansys EmployeeCan you please check to see if the conductivity of the object is defined properly? Â
Also, ensure that your excitation defined on the coil in Maxwell is setup in one of two ways:Â
1. The coil terminals extend to the solution region, where the excitations are assigned on the start and end of the conductor.Â
2. The coil terminals form a closed loop, where the excitation is assigned to a cross section. Â
April 8, 2019 at 8:25 am
ikra
SubscriberThank you very much mark for your help.Â
Now I have another error "setup error, possible reasons are 1) The solved region is not singly connected. If any circle in the solved region can not be freely shrunk to a point, then solved region is not regarded as singly connected. 2) The master and slave boundaries are separated. For this case, “Zero Tangential H Field boundary condition need to be assigned on one boundary connecting master and slave boundaries".
 I have as model a cercular coil with two conduction pads, near to a metalic target. Â
May 3, 2020 at 1:53 pm
sarathmail63
SubscriberI too had the same issue, can anyone knows or solved this issue?
- The topic ‘Error: system matrix is badly conditioned.. 1%’ is closed to new replies.
3367
1050
1047
886
831
