December 29, 2023 at 12:57 pm
Juan Martin
SubscriberHi all, I am following the tutorial for the ANSYS master, optimization module, optimizing turning vanes.
I follow all the steps of the tutorial, but I can't get the same adjoint residual behavior, they are not converging.
Is there something missing?
Best regards, thanks!
January 4, 2024 at 7:32 am
Nilay Pedram
Forum ModeratorHello,
Can you please share the link to the tutorial which you are referring to? -
January 5, 2024 at 2:14 pm
Juan Martin
SubscriberÂ
Hi, thanks for your reply, sure, in the attached link you can find it. I am not able to get the residuals to go down although I have followed all the steps. I include the case and data file for you to reproduce the case.
January 5, 2024 at 3:14 pm
Nilay Pedram
Forum ModeratorAnsys staff can not download any files on the forum, so if you want to reach a larger audience to get answers from, please insert inline images describing your problem.
January 5, 2024 at 3:52 pm
January 8, 2024 at 12:48 pm
Murari Iyengar
Ansys EmployeeWhich version are you using?
January 8, 2024 at 1:39 pm
Juan Martin
Subscriber2022R1 and 2023R1, getting same results in both of them.
January 10, 2024 at 7:02 am
Murari Iyengar
Ansys EmployeeWhat do your results look like? Residuals don't necessarily have to converge for calculations to be correct.Â
January 14, 2024 at 9:24 pm
- The topic ‘Application tutorial not working – optimizing turning vanes’ is closed to new replies.
6670
1313
