Error in rotational periodic boundary condition
    • GOKHUL K
      Good Day,
      I have a k-epislon turbulent case of ejector (quarter symmetric-90 degree, 3D geometry) here . The case is running when the side walls kept in symmetry, there is no error, but the problem is if i put periodic boundary condition-rotational, the parameters rise at the outlet at any cell and error occurs within 10000 iterations. Please help me out with this..
      Thanks in advance...
      FYI: the whole geometry is splitted into many solids and th mesh is fully hex, done by sweep method and the mesh looks fine.
      It diverges at around 10k iterations? How does the flow field look prior to that happening?
  • The topic ‘Error in rotational periodic boundary condition’ is closed to new replies.
