Preprocessing
Preprocessing
error in iMporting mesh from ICEM to FLUENT
    • namratha98
      As soon as i import my mesh file(.msh file) from icem to Fluent, i get this error. what would be the possible sources of this error?and how do i correct it?
    • Keyur Kanade
      did you check the mesh in icem?
      please check it. if it has any errors, please fix them using edit mesh > check mesh.
    • namratha98
      yes.. and i found the error. In ICEM , proper associations has to be done. In my case, one curve wasn't associated to an edge and this kept creating an error.
    • Keyur Kanade
      good.
      if this helps you, please mark this post as 'is solution' to help others on forum.
  • The topic ‘error in iMporting mesh from ICEM to FLUENT’ is closed to new replies.
