Ansys mechanical – Not able to restart solution from saved restart points
    • shailesh.fulse
      I am currently performing a structural analysis of big frame with bolt pretensions. This is very big model so I have selected restart points manually at each load step and substeps. I have stopped the simultion after load step 1 and substep 4. Not I wanted to restart from that point but I got error mentioning restart point is invalid and solve from time zero. I have tried to start from subtep 1 or 2 but still same error. This has happened few times now. It will be helpful if some give me solution to this error.
      Thanks
    • danielshaw
      Did you save the necessary restart files at those result sets?
  • The topic ‘Ansys mechanical – Not able to restart solution from saved restart points’ is closed to new replies.
