Harmonic Analysis- No node hit found ( rotational force)
    • Hadi96
      Dear sir,  i had done harmonic response of rotating shaft with connection of 2 bearing, but after i insert rotating force at the shaft, it said that no hit point node found, how do i solve this issue?
    • shubham chauhan
      help plz
  • The topic ‘Harmonic Analysis- No node hit found ( rotational force)’ is closed to new replies.
