The fl process could not be started.
    • antoinel
      I saved a case and corresponding data file in Fluent. After saving, I closed Fluent. Then, I opened Fluent and read the case. When I attempted to read the data file, I received the following messages that began with
      "999999: mpt_accept: error: accept failed: Invalid argument"
      for more than 100 pages and ended with
       "The fl process could not be started.
      Is there a bug in Fluent that is causing this error? How do I fix this error?
    • DrAmine
      Which version are you using?
      Can you read another case/data file`?
    • antoinel
      yes
    • DrAmine
      Start parallel but give 0 as number of CPU: Can you now read the file?
    • antoinel
      No.
      I received the following error.
      Error: received a fatal signal (Segmentation fault).
      Error Object: #f
    • DrAmine
      Possible the case is corrupt: Which models were activated.
    • antoinel
      Viscous Laminar
    • Keyur Kanade
      open fluent in meshing mode.
      go to windows start > fluent >  click on meshing mode.
      read case file in meshing mode and check the mesh.
      then you can switch to solver mode.
    • antoinel
      I tried the suggestion from the previous post, but I received the following messages and fluent could not be started.
      The mesh has been modified.
      Previously saved data files are incompatible and cannot be read.
      The fluent process could not be started.
    • Keyur Kanade
      did you try suggestion of parallel post or suggestion of meshing mode?
    • antoinel
      I tried the suggestion of meshing mode.
    • Keyur Kanade
      so when you tried to read case file in fluent meshing, it gives error.
      then most probably your case file is corrupted.
    • thamarai
      Hi,nI have have .cas file and I tried reading in the FLUENT 17.2. Getting the following errorError at host: Build Grid: Aborted due to critical error.nnNote: Separating interior zone 15 into zones 15 and 2.n==============================================================================nnNode 0: Process 11616: Received signal SIGSEGV.nn==============================================================================nnError at Node 1: Build Grid: Aborted due to critical error.nnError at Node 2: Build Grid: Aborted due to critical error.nnError at Node 3: Build Grid: Aborted due to critical error.nn==============================================================================nnNode 4: Process 14968: Received signal SIGSEGV.nn==============================================================================nn==============================================================================nnNode 5: Process 17076: Received signal SIGSEGV.nn==============================================================================nnError at Node 6: Build Grid: Aborted due to critical error.nn==============================================================================nnNode 7: Process 13236: Received signal SIGSEGV.nn==============================================================================nnError at Node 8: Build Grid: Aborted due to critical error.nn==============================================================================nnNode 9: Process 13788: Received signal SIGSEGV.nn==============================================================================nnError at Node 10: Build Grid: Aborted due to critical error.nn==============================================================================nnNode 11: Process 16776: Received signal SIGSEGV.nn==============================================================================nnNote: Separating interior zone 15 into zones 15 and 3.nNote: Separating wall zone 16 into zones 16 and 4.nnError: Failed in Fill_Domain.ote: It is possible that this case or mesh file needs to be firstnMPI Application rank 0 exited before MPI_Finalize() with status 2nprocessed by the serial solver. To do this, please readnfile into the serial solver and then save it. Next,nread saved file into the parallel solver.nn The fl process could not be started.nnPlease help me.nNote: I also tried Run the system with parallel with 0 processor as said above but again got the same error.n
Viewing 12 reply threads
  • The topic ‘The fl process could not be started.’ is closed to new replies.
