February 21, 2019 at 8:13 am
Jamessmp23
SubscriberHello,
Does it possible to fix the desire number on colormap option in fluent contour ?
I have a simulation results like this, and I want it to be the same scale on colormap.
Any suggestion ?
*PS. I found the discussion post on 2013, they said it was a limitation on fluent colormap.
Best regard,
James -
February 21, 2019 at 9:55 am
Forum ModeratorYou mean fix the range or the number of colour bands? The former can be done in the various Results panels (contours, vectors) just turn off one of the settings. If you want to adjust the bands that's also on the results panel. The colours can be altered via View -> Colormap.Â
February 26, 2019 at 3:41 am
March 4, 2019 at 12:35 am
Jamessmp23
SubscriberOkay. I mean according to the picture, the top red color it should be 1.12e+00 for all of the similar simulations and each colors on the scale should represent the same numbers for all of similar simulations . Can it be adjust ?
I tried to work with the colormap(changing type, precision, colormap size, log scale) but it doesn't solve my problem.
regards,
James -
March 6, 2019 at 3:33 am
Keyur Kanade
Ansys Employeein contours dialogue box, please deselect auto range. then you can give inputs for min and max.Â
if this helps you, please mark this post as 'is solution' to help others on forum.
March 7, 2019 at 2:30 am
Jamessmp23
SubscriberThank you for the answer simple and clear.Â
- The topic ‘Does it possible to fix the desire number on colormap option in fluent contour ?’ is closed to new replies.
5834
1305
