February 19, 2019 at 12:43 pm
Kepojeyathas94
SubscriberHi everyone.Â
I'm using the solar loading model (DO model and Solar ray tracing) for my building simulation with Fluent. Should I've to set a specific value for the free stream temperature and external radiation temp even I'm using the solar loading? Can you please me explain the meaning of these two temperature? -
February 19, 2019 at 5:09 pm
Forum ModeratorFree stream temperature is used to allow convective losses to the environment (or heat addition if the environment is warmer). Read through the documentation on the solar model & wall heat transfer: for most cases free stream & radiation temperature can be set the same. It's been a while since I last looked at this so do some testing.Â
- The topic ‘Free stream temperature and external radiation temperature’ is closed to new replies.
Ansys Innovation Space
- affinity not set
1414
1241
1118
1015
