Exact meaning of contact status options?
    • Rashi
      Hi All,
      In the contact status options what is the exact meaning of each status?
      From what I understood,
      Sticking - no tangential movement between the two contact surface
      Sliding - there is  tangential movement between the two contact surface
      Near - contact surface has normal separation within pinball radius.
      Far - contact surface has considerable separation
      Over constrained - How can two contact surface be over constrained, this I do not understand.
      Thanks in advance.
      Rashiga
    • Rashi
      Any clarification regarding this matter?
    • sathya
      I request you to go through this link to get your doubts cleared.
    • Ashish Khemka
      Please see if the link below helps:
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v193/wb_sim/ds_Contact_Results.html
  • The topic ‘Exact meaning of contact status options?’ is closed to new replies.
