February 12, 2019 at 8:10 pm
SumitPatil
SubscriberI want to apply forces on a region of my upright geometry at the place where bearing is mounted. How can I select the cross section and apply load on it -
February 13, 2019 at 1:04 am
peteroznewman
SubscriberUse DesignModeler, create a plane at the desired location and use it to Slice the geometry into two bodies, then select the two bodies and Form New Part to create a multibody part so you don't need bonded contact. Now you will have a surface and an edge where the bearing is mounted. You can even put two planes close together to make a surface for the bearing seat.
February 13, 2019 at 2:54 am
SumitPatil
SubscriberWill it work if I want to distribute all the load equally on the nodes in that area just like a rigid connection..?? -
February 13, 2019 at 11:53 am
peteroznewman
SubscriberIf you select a face, it will distribute the load proportionally to all nodes on that face. A force is different than a rigid connection. Please reply with an image to illustrate what you want to do, the boundary conditions and loads you want to apply if you need advice on how to build your model.
February 15, 2019 at 12:06 pm
February 15, 2019 at 4:48 pm
peteroznewman
SubscriberThe post above is marked as Is Solution. Does that mean you no longer need any input on this model?
February 15, 2019 at 4:52 pm
SumitPatil
SubscriberNo by I need the solution for it by mistake I marked it as solved bit I haven't got any solution for it. -
February 15, 2019 at 4:54 pm
SumitPatil
SubscriberPlease help me to solve this problem -
February 15, 2019 at 5:10 pm
peteroznewman
SubscriberI understand you have a bearing face you want to apply a force to.
What else attaches to that part? Please show that part in context of adjacent connecting parts. Somewhere there is ground. What is the path to ground?
February 15, 2019 at 5:22 pm
SumitPatil
SubscriberMy upright is attached to the hub which is further attached to tire now my forces on tire will distribute in the upright through this bearing seat -
February 15, 2019 at 5:50 pm
peteroznewman
SubscriberPlease insert images with the load path through that part.
February 18, 2019 at 4:46 am
SumitPatil
I have two bearings here on this upright which are connected to hub which is connected to my tire,my upright is staionary.hub is rotating over this bearing.My forces from tire are transferred through this bearing.
I have a brake calliper connected via bolts at this two marked holes.my calliper is connected to rotor which is rotating.calliper is stationary. I have not imported the geometry of calliper as it is a different part so how can show that there is a connection by using 'joints'. cause in joints i have to specify stationary and mobile surfaces.
I have a upper controlling arm connected to upright using ball joint at the top face similarly a lower control arm at the bottom face.
So how can i show all these connections without importing whole assembly as I just want to analyse my this part??
- The topic ‘Applying load on a selected part’ is closed to new replies.
6465
.jpg?width=690&upscale=false)
-li.jpg?width=690&upscale=false)
